182 FF, A6 Avant
So frustrating!
Bled through my system with new fluid. No air got in as I had help and we kept a constant eye on the fluid levels. I bled a litre of fluid through it and initially the pedal felt fine. Since then It's got softer when the engine is running and I can get the pedal to the floor.
I've re bled it again today and got a few bubbles out, but not a huge amount. Pedal goes rock hard after a few pumps when the engine is off, but still goes down when the engine is running.
Have double and triple checked for leaks and there are none.
Bit concerned that I've got air in the ABS as I've seen mentioned, it's the only thing I can think of at least. Hopefully it will rain tonight and I can go out and try to fire off the ABS as I've seen suggested. Currently there isn't enough stopping power to do it in the dry!
Anything else I can do/check/try?
Thanks.
Thanks.
