Solid Edge - Drawing gears
Car  S2000
Does anyone off here use the solid edge program for making 3D drawings?
Using it just now for a uni project but I need to draw some gears and can't get it to work. The problem is that it's a really small gear wheel, about 20mm diameter, but everytime I put in the spec I need it just makes a cylinder without any teeth. I can make gears of bigger diameter fine but really having no luck with this.
Anyone know how to make these smaller gears?
Thanks.
Forgot to say but I'm using V18.
Mods - you are quick tonight that was up no more than 30 seconds before it was moved, lol. Always forget the tech part exists.
