M2,XJS,S1000RR
been spraying some plastic, bought some plastic primer and paint, got some wet and dry and went over the plastic to rough it up and key the surface, then washed it with white spirit to remove grease etc, and the dryed it off.
sprayed the primer onto it, can said leave for 15minutes between coats, so i left it 15 - 20, and put 2 coats on, but then the primer has cracked on the surface, its completely dried now on the plastic, should i put more primer on it and try and 'fill' in the gaps, or strip the primer?
also, what is the best way to strip it off the surface?paint stripper?
