Some MS Word Help Please
  AB182, Audi A5 3.0
I havent downloaded the files, but im going to hazzard a guess the text is in a textbox over the label?
  AB182, Audi A5 3.0
No what I mean is, your selecting the backing image, but not the textbox that sits above it. to select both, use the ctrl button to select the image and the text box before cutting.
The Boosh!
ClioSport Admin
  Elise, Duster
It's something to do with the grouping as when I ungroup and copy separately it works fine. The easiest way around it would be to just screenshot it and copy and past. You could f**k about all night and get it eventually but for the sake of a screen grab it's not worth it unless you need it in text format.
Andy_con
  clio 182
um but ive grouped everything so normally its one click to select all
but ill give it a go
  AB182, Audi A5 3.0
ok i have opened the documents, the problem is with the formatting - the text is there, its just further to the right. you need to reduce the line spacing on this text... expand the box with the tex in to the right and you will see what i mean...
  AB182, Audi A5 3.0
the command you need to use on it is 'remove space after paragraph'. then reduce the line spacing on all text, then make sure the box with the text in is sent to the back.
your welcome.
  AB182, Audi A5 3.0
here... also make sure you set the font to arial as it will default to calibri normally...
  AB182, Audi A5 3.0
sounds like fun! Whats the biggest you have ever made? I wanted to build a semi-buring laser from a blu-ray player, but havent got around it it yet! wanted it to burn images into wood...
Andy_con
  clio 182
Biggest? In actual size or power?
Www.laser-man.co.uk
I've built 24 diode lasers, £7k projectors, 5 colour projectors...
You really want to use a 445nm diode from a Casio a140 projector. They are 1watt in power and a nice low wavelenght for burning
