sony mex-bt3900u - does not remember settings
Car  Clio 182
Hi, I've installed a sony mex-bt3900u which I bought from eBay. It works ok but does not remember the time and resets itself every time I use the car.
Is there a battery which can be replaced or suchlike?
It's plugged into the universal plug but should I be giving it non switched power perhaps?
I'm new to this stuff but am learning quickly :). Any help welcome !
Thanks - could you elaborate a bit more please? Do I need to take the plug apart to swap the wires?
They're usually on bullet connectors so you can swap them round easily. Basically, ones a permanent live, and the others a switched.
Thanks - I checked the loom again and sure enough the red and yellow wires have both been cut and joined to each other. Not sure why this would have happened ?
Anyway I'll get my soldering iron out tomorrow and try to fix this.
