Sore Fingers!!!
  Clio 1.2 16v Dynamique
Wotthefook??
Right... just TRIED taking off the door bumpstrips!!! the bullets came off easily enough but the main strips were a little tough (really thought i wz gonna break them) so ive left them on for now!
Is there a more succesful way of gettin them off? tried pullin them toward the door but that wz onlt makin the strips bend. i could see the 2 lugs beneath the bullit part but couldn't free them either!
anyone know a better and less painful way of gettin these buggers off?
Also need to remove the plastic inserts on the front and rear bumpers... anyone know how to do this?
All help welcome
Phil
  ITB BG 182
front a rear bumpers take em off then take off the foam paddin on the inside an youll get to them easily.
Also with the doors take of the door card inside an press together the clips from there an lift out.
cheers. installing new speakers aswell this week so i can do it then whilst the door card is off
  Clio Dynamique
If you look on the inside of the doors there is a round black plastic cap the size of a 2p coin, you can take this off and use a small screwdriver to push the plastic clip (its down and in a bit, shine a torch in and you should see it) that locks them on in. I can take some pictures if you need, as I have a set of trim not on the car. I also have a file with instructions for taking front and rear bumpers off, let me know if you want it and I can email it to you.
