Spacers for phase 2 172???
len_beach
  E92 M3,172 track car
I've just bought a set of Turinis for my phase 2 172. I have wanted to spcae the wheels since day 1 as I always thought they looked a bit 'in' LOL when looking from behind.
What would be the optimum spacing to take the wheels out to 182 spec or would even further out be better?
I have checked Tweeks but they all require a phone call. Who makes the best 172 spacers?
  172 cup'd extreme
turinis are a wider offset than then mk2 172 wheels giving the cup its wider track so will look better no need for spacers
  MKIII 138
ahh.. but i have a cup with turinis and they look to 'in' lol at the back, im getting some 20mm H&R spacers all round boosting the 40mm open rear track over the 172 to 60mm wider, phat + getting H&R`s coilovers also so phat and low.
http://www.performancealloys.com/alloy_wheel_spacers.asp
h&r do good stuff, bit confusing as to which type i need but im gonna give them a call first, probably my next mods after fitting my hillpower kit this weekend
hope this helps
len_beach
Thanks for that Megs. Did you see the post about the tints for £115?
When you call tomorrow can you ask how much 2 sets will cost as I would still be interested in a set if there were no issues with rubbing.
hope this helps
  MKIII 138
no probs
  172 mk2
ive got turinis (from a cup) on my 172, fit fine.
im running apex springs (40mm) and when a 215/40/16 tyre on the back got some rubbing.
if your going to lower your car, think 20mm each side will be way way to much!!
len_beach
Sounds like you've already put my plans into action Howie. My next mod was to be Apex after a de-cat next week.
So you think I should stick with the Turinis as they are, no spacers?
len_beach
Fred2001Dynamic said:
20mm spacers!!! you MUST be smoking crack if you think they'll fit!!!!
Will any spacers fit/will I need any spacers Fred if I am fitting the Turinis?
What is the difference in offset between standard and Turinis?
  182
LOL..
Fred please explain some more.. I still aint got those 5mm spacers for the front that you recommended I use, I keep thinking koni shocks instead...
Rob.
  Lionel Richie
std wheel = ET48
cup wheel = ET 38
the number is in mm, and is measured from the centre line of the wheel
now this is the bit you have to get your brain around!!
ET60 would mean the wheel would be really far in to the arch
ET10 would mean it would stick out of the arch
if you put 10mm spacers on a std 172, you'd get the same effect as bolting on ET38 wheels
you get it now??
