Spacers
r1chardson
Car  Clio 182
Well im going to have 2 5mm spacers soon as i got them really cheap. My question is, is it best to put them on the front or back? Wether its for performance(if it even makes a difference) or looks.
Cheers Joe
firstly check your wheel bolts are long enough to use spacers safely.
there no right place to put them personaly I'd probably have them on the back but each to there own some would prefere front.
How do you know if your bolts are long enough to use the spacera safley?? Is there some kind of test i can do?
My standard bolts were long enough to use for 5mm spacers guys.
If i had to chose, id have them at the front rather than the back, especially if the car was decked at the front wheels get well hidden undeer the arch.
ah loverly, so im assuming when choosing the longer bolts il measure mine and just add what ever the spacer is to it. cheers matey
