Spacers
Barron
  Turbo S,Exige,R5,182
Looking for some 15mm hubcentric spacers for the track car. I will be using extended bolts so dont want ones that bolt to the hub.
wheres the cheapest place for them?
thanks
carl
Barron
its CARL not karl, karl is the poor mans way of spelling it.
anyway i am going to do that, website link to yours?
ta
carl
  Lionel Richie
studs and nuts are about £70 (can probably be done cheaper though)
spacers are £45 per axle IIRC
not cheap, but good
  340i
ahhhh the dynacup :)
Currently looking for some... what do the cup's run compared to a PH-1
20mm more front track
10mm more rear track
:S
  Lionel Richie
i couldn't tell you off the top of my head, remember phs1's have ET(can't remember) and cups are ET38.5
a cup is 20mm wider on the front and 10mm wider on the rear over a normal phs2 172
  340i
meeeh... may just go 10mm all round!
With a wider track, would that allow you to run more negative camber?
I run 1.5 negative IIRC any more than that scrubs the inside of the tyres on the coilover
