spark plug question
Car  Trophy #267
combination that i have bob hope of getting any further warranty work from renault dealer due to my accoustic valve incident plus i love to do stuff myself and im skint atm means ive ordered a set of NGK PFR6E-10 from local motor factors. I correct in thinking they need to be 1.0mm (maybe the-10 part of the partno :) ) and that they are already pre set ? Also can i get away with reusing the gasket for the inlet manofold which you have to remove or do I have tor replace ?
Rob
Usually these days they come present and not asjustable a good motor factory place will only sell you the ones with the right gapping.
You can resuse it I wouldn't bother.
NGK PFR6E-10 Is the correct plug they are between £7-£10 each from factors Gasket is ok to reuse ive only changed mine once and the mani has been off 10ish times lol
