Spark plugs.
Just tried a search and couldn't really get an answer :S people just say they're using NGKs, but no reason why other spark plugs would cause problems. Easily confused :( Jon
I wouldn't have thought so no.
But then i'm not a car mechanic. Or a Carpenter.
compatability isn't to do with the engine. That's not actually possible. It's down to plug resistances and loads put on the coil being incorrect. NGK plugs are consistently reliable with the correct resistance.
PFR6E-10 are the OE plugs. These are exactly the same spec as BCPR6ES but using a platinum tip which is generally used for cars with a catalyst. You'll often see these 2 plugs used in the same application where there is cross over year between a non cat and cat equiped version
