spark plugz
  Clio 1.2 16v Dynamique
time to bug the technical minded here
does higher quality ignition leads and uprated spark plugs make much difference to your car?
Nothing major. Depending on your car it may run slightly smoother.
Notice you have a 1.2 16v in your profile, you cant get aftermarket/uprated leads for these as they are fixed into the coil pack so must use standard ones.
Plugs, either the standards ones (champion) or NGKs are good enough.
mine felt better but i had a service at the same time ......stock parts aren't bad but i went for summert long life
Which plugs did you go for? Mines done 51k miles now and i reckon its time to change them.
They've never been done!
Stock leads are more than enough same for plugs there very good hence why some tunners use them for properly tunned cars.
