Okay so basically I'm wiring up 2 6x9's at 600 watt peak power each, and 2 subwoofers at 900 watt peak power each.
Okay so I believe with speakers you should always step up the wattage, no idea if this is true or not? So I'm thinking 1200 watt is the peak of the 6x9's so they should be wired o a 1500 watt amp, while the subs peak at 1800 watt so they can be wired to a 2000watt amp, these amps are then wired to a distribution block which has a wiring kit of up to 5000 watt running to it.
Is this the correct way to go about it?
