Oh, be careful tho.. if you have no speakers in the door cards, you probably have manual windows? If you put a speaker there, you can no longer turn the winder properly.. so you either have to position it differently or convert to electric windows in the front.
NeilDown, 10cm m8. I had to cut the door cards, if you take the door card off theres a shape that can be cut out 2 fit, 13cm will fit and if the magnets arent too big then the window wil still go up and down ok
jus run the wire from the back of the stereo behind the footwells in2 the doors, i used a mini-circular saw 2 get thru it, easy enuff! i dont think it would crack, its not really that thin, and i dont think u wil fit 6x9s in the doors
