Speedo dash issues
Car  clio sport 172
do they often blow bulbs? Or are they LEDs? I have a 2005 clio 182 and when key in ignition the abs,esp,airbag,serv, and power steering don't light up
i had the same issue, turns out the guy i bought the car from had actually snapped them off the circuit board to stop the lights coming on as it had fault codes for abs and airbag, best to whip out the dash and check the bulbs are there
ok got dash out as I thought they were tapped up but strangely abs/esp is fine only issue is a serv and airbag light so which is normal issues under seat switch? also there is deffo no fuse in my power steering in fuse box and only 1 metal tang there no fuse wouldn't work if there was 1 there
it may be fine until you drive the car, could have issues with abs rings or brake pedal sensor etc.
Just checked under drivers seat and it looks like the black connector is broke is it best to cut black connector off and solder the 3 wires?
you can solder the wires yeah, or another option is go to a breakers and find a good connector cut it and solder it in place then that way if you ever have to take the seats out you can just unplug it
sorted airbag light and have put everything back together and no lights but the speedo not working now :-( any ideas can they be fixed or new speedo?
just add it worked before I removed dash and I had to prise edge by it to remove tape over airbag light
Hold the button in on the end of the wiper stalk and turn on the ignition this will make all the lights come on on the instrument panel, look and see if the speedo is moving
if it isn't your probably going to have to take it all back out and check the clocks
it is working now but wouldn't say accurate so may need new speedo as someone messed with it so needles may now be in correct position
