Spongy brake padel after track day - bleeding does not work
Car  RS Clio 182
I went for a track day on saturday and after cool down of the first 25 minutes the brake pedal became really soft. 2 days later still the same: bad feel and poor stopping power. After reading several post, I bled the brakes in a workshop. But nothing has changed at all. Disc s and brake pads (ebc yellows) are new (1500 miles), braided lines and motul RBF660 racing. The system worked really awesome so far. Any ideas of what is wrong? Probably not proper bleeding due the abs clip?
If you pump the pedal,does it firm up hard with less travel?
You might have air in the ABS pump as you stated, do have a thorough inspection of all unions and brake lines as you could also have a leak somewhere, which is letting pressure out of the system.
Thanks, I will need to check with the workshop. I did another beeding cycle as EBC reccomends and after this things are much better now. I think they are still a bit softer than before trackday but good enough let's say. In any case thanks Dannyeff, I will check next time!!
