sportlines changed handling charteristics
My car with sportlines now feels slightly more back end happy but quite a bit stiffer aswell, could this be the reason for it "sliding slightly more" ?
Any input appriciated
Rob
haven't had the tracking done ? Why do i need to have the tracking done again, only springs changed .. Cheers :)
Had mine on for 350miles (had it tracked after 200miles) now and the car has felt fine since day one, your tyres ok? As you'll now have less body roll you'll be putting more force on the tyres when cornering.
If the car is lower, your geometry will change. Fred advised a few weeks, then tracking and alignmet check. Made a difference on mine.
Yeah dont get me wrong feels fine just a bit more slidy think its due to stiffness though..., tyre pressure might be a tad high think there at 34F 31R
As per the others I got mine tracked and it spot on but when you did the rear springs did you check the rear dampers , mine felt slippy and unsteady from the back and was knackered rear dampers.
