sports pedal setup on a 1.4 16v dynamique?
pedal set up??
what do you mean by this?? im not sure if changing the pedal box with provide any improvments?!
in theory it will all fit fine, but youll need to make sure both are cable throttle or both are digital throttle.
im not to sure what clutch cable you will have to use either!
sorry i meant the oedal box yeah and the box came off a ph2 172 so that means fly by wire throttle doesn't it
and steph.'s ph2 1.4 is definately electronic throttle
