Spot weld drill bits
  Rb 182
What size spot weld drill bit would i need to take the rear seat mounting brackets etc out the inside??
I think it'll be a 8mm, but can anyone confirm this??
I think I used an 8mm one, drilled all the seat brackets out on mine
Get a drill with variable speed and use it on slow in pulses though - they're sharp as hell and go straight through the french tin can body work in seconds
Gally
It's definitely an 8.0mm mate. We stock them. :)
  Rb 182
Cheers for the advice mate :)
I thought you saved your special cuddles for me? :(
Meh, your never around much anymore.
It's definitely an 8.0mm mate. We stock them, and i'll get you a handfull if you wish? :)
Cheers mate.
