spraying 1.2 16v Spoiler
Car  Megane DCi 147bhp/350nwm
Is it easy to remove? what preperation would you reccomend before spraying it as it seems a wierd surface compared to what i've sprayed before...
should i just use brake cleaner to get rid of akk the silicones and grease, grey primer a few coats, black a few coats then clear laquer?
i can get a perfect finish to it, i'm a good sprayer...i've done all my plastic moulds and door handles etc, just thought you guys may have some good prep tips for it and if its easy to remove/put back on
1. open boot
2. remove 6 torx screws
3. shut boot
4. pull hard
5. unplug the electric cable for light
6. unplug the washer jet feed
7. done :)
i'd get it done professionally, but if your handy with the cans then why not
