I have a Mk2 Clio. Thinking of spraying my diamond Renault badges black or grey. Im just not to sure of how to go about it. Do I just apply primer leave to dry then spray colour? And also how are the front and back badges removed? Thanks...
you need to sand them down/key them properly, then apply a plastic primer (don't use halfords, its crap) then a normal primer, wet sand, then paint and lacquer
its a term used when sanding to create a rough surface for the plastic primer to adhere to easily, before using high build primer to smooth the surface out.
I've recently done mine... Give them a sand to rough the surface up... Ten plastic primer leave to dry, paint, few coats, then Lacquer.. Leave to dry over for a good few hours before fitting....
I used halfords primer and paint and found it very good... But I guess it's personal preference.
