One thing I've noticed over the years is that it seems very difficult to come across information on spring rates when looking to buy new suspension.
I was looking at the car the other day and I'll admit, a little ride height reduction would make the 182 look a bit better. Eibach seem to be a good shout as I don't want to go down the coilover route...yet...
The only problem is, other than the reputable name, you don't actually know what you are buying? I would like to know what the standard Clio 182/182 Cup/Trophy spring rates are and how these compare to the after market options. Are the standards springs progressive rate or not?
It seems to be a lot easier to find this information for Japanese car. A quick search on the net and you can find out exactly what the spring rate of a 1998 Civic EK9 Type R is in kg/mm. A friend of mine changed the suspension on his Integra and know he went from say 5kg/mm to 7kg/mm at the front and 4kg/mm to 6kg/mm rear. This would at least give him an idea of the potential handling characteristics.
Any thoughts?
Any thoughts?
