Squeaking Brakes
Tom
  i3
Yo Homies
after recently changing my pads up front they squeak on oneside i copper greased em and bed them in properly but the still squeak after 700 odd miles
whats wrong with em?
ps: they work really well and the pedal feels fine
Well ok, ill go through all the possibles.
The squeaking is caused pad vibrating against the rotors, to avoid this they are clipped or glued or crimped to the caliper to reduce it, therefore the pad might not be fixed on properly!
Also brake dust and other sh*t can clog up areas which might prevent 100% contact with the pads and causes squeaking. Easy solution is to spray it all down with water though ideally you need to scrape all the channels clean, be careful though, inhaling brake dust is very dangerous!! Would probably have to take pads and calipers off as well.
The only other thing is the glazing which is what ive mentioned already.
Cant think of anything else mate.
-Rob
This might sound extreme but you can remove the pads and on the LEADING edge on forward wheel motion, grind a very small camphor, just a small 45 degree angle on edge. This often stops them squeking, and you are talking about a millimetre or two in lost pad area, which aint going to make any difference anyway, and the material is designed to wear away, so its not as daft as it sounds. Try that if you cant get rid of it any other way.
Tom
  i3
Spoken to mintex and they are sending out a new set of pads :D
sometimes there are dodgy batches
cheers might try the leading edge part mate
