Standard brake fluid
What is it? I seem to recall its Dot 4? And Dot 5 is seen as an upgrade?
Changing the rear pads tomorrow so need some just as a top up etc, but can't be arsed to flush it!
I did do a search but didnt find anything!
Ok cheers, surely someone must know which is standard?
As far as I'm aware you can't mix fluids, but if I run low on fluid when doing the rear pads then I'll obviously need to topup with what I have already!
