Standard Clio 182 airbox
Car  FF Clio 182
Just a quick question, on the standard air box there is an inlet pipe that branches off the elbow hose and goes down behind the engine, should it be plugged into anything ? Or should it just be loose not plugged in?
Thanks in Advance
loose, its a low air intake, i personally think it just sucks in hot air from the engine but meh! tis fine
sorry wrong pipe, that one supplies oil to the intake valve, that one needs to be plugged in, look behind the manifold you should see a tube sticking out that the pipe should be attached too
The hoses is a oil breather return there should be a brass fitting at the back of the engine. Push it onto that.
Then the oil vapour will drip on the manifold instead of being burnt off in the engine.
I use one of these instead as i'm using a silicone elbow with a V6 box.
I heard using a filter can create back pressure and blow your seal? Like I said I heard it, doesn't mean it is true
Never heard that myself. Not sure how a filter can create that level of back pressure, If you keep an eye on it and make sure its not getting clogged up it should be fine.
Yh that's what I thought but I thought I would just mention it :)
My only concern is what is on the back of the engine if the hose isn't plugged in and I can't see any connections for the hose to plug into
