Standard Radio
  Mk2 Phase 2 Clio
Right...
My radio's started playing up, its no longer starting automatically when i start the engine and also not turning off when i turn the engine off. I have to manually turn it on and off, i know its nothing major but its just annoying because it was working fine yesterday.
Also, i can be driving along with radio/cd player on and it will beep a few times and then turn itself off.
Can anyone shed some light upon this problem?
Oh, just to add, i recently added some 6x9 speakers but i didn't remove the head unit.
I just daisy chain connected them from the rear speakers?:S
Cheers in advance
  Dodgy one
Its the fuse, just had it on mine its on the passenger side if you open the door. Its the 20A one. In two rows from the left and 4 down if that makes sense lol
  www.renparts.co.uk
as rich 6 says its a fuse, same fuse for your ciggy lighter, you will find that doesn't work either, usually blown because of someone shorting the cigarette lighter, people sometimes drop coins in the hole. as you say stops radio coming on with ignition.
