Starter Motor
Car  Clio 182 cup
This is for info for anyone searching starter motor.
Just changed my starter motor on my 182.
Warning: looks like the right angled main terminal tag needs to point upwards in order not to foul on the manifold. When picking up a new starter make sure the main terminal tag will not be up against the smaller solenoid terminal post, I have had to run 2 extra nuts down the main terminal post to get clearance. ( tag fitted on top of the 2 extra nuts) a Lucas unit looks like it won't have any problems as there is no small post under the main tag.( Lucas unit I picked up had the plastic separator broken off so no use )
It's loosen off exhaust manifold, air box and inlet off for access. Not the best job in the world.
