Starter Relay 172
Fishfire
Car  Clio 172
Could someone put a pic up of the relays identifying which one is the starter relay please.
Phase 2 Clio 172
A part number would be handy too 😉
The car is intermittently failing to start. I fitted a brand new starter motor as that was also sticking. I've had all the relays out, cleaned up and given a gental tap then reinstalled.....the car starts first time after this but will then intermittently not turn over after a while, so fairly confident it's the relay playing up.
TIA 😁
Its the middle one of the small 3 in the underbonnet fusebox iirc. Can see the white exciter wire going into it at the bottom
Gleaming! Cheers dude.
I guess this is the relay I need then?
Looks about right in the pic. Check the spade connectors in fusebox for corrosion.
