Starting issues after engine swap
I've recently reshelled my turbo engine from my ph2 172 into my ph1 using the ph2 loom as my adaptronic eco is wired into that
went to start it last night, and the cars just turning over.
not getting fuel or spark, changed the TDC still no luck...thinking its electrical or something between ph2 loom in the ph1
Anyone able to help??
What are the lights on the dash doing? Do you have a solid red?
If not is the fuel pump priming?
is the adaprtonic piggybacked on to the clio ecu? if so you trying to run phase 2 ecu in a phase 1?
This, and will the interior loom to engine plug not also be different pins from ph1 to ph2?
Yeah it is and I tried that at the time did t work
What throttle are you using?
Cable throttle from a mk1 megane 8 valve but I used it last time
The dash lights are coming on but some don't go off and the Rev counter and speedo don't move when the ignition is turned on so might be a possibility
you'd need to change the wiring in the car to use the phase 2 uch.
only practical way of doing it is using the phase 1 ecu.
