Starting problem
deanoE30M3
Went to move the other Clio ph 1, went to start and it keeps spinning over!
The immobiliser light wasn’t flashing but Just won’t fire.
I’ve just put some more fresh fuel in it.. any suggestions?
deanoE30M3
Got round to scanning it!
Here are the codes..
deanoE30M3
I’ve just had the sigma alarm taken off, it had started today after 2-3 months of not starting.
The red light goes to solid but just spins over has anyone had this issue!
Could it be down to the key?
Am going to try and have a new key programmed to the car again, tried before the alarm got taken off thought that this was the problem!
  Bmw M4 & Clio 16v
I'm having exactly the same issue - spins over and won't fire - have no power to fuel pump or 5.45v at least and a clicking from the inlet
How did you scan yours? ODB? didn't think mine had one?
deanoE30M3
I’ve not checked power to the fuel pump as yet!
The bod is under the ash tray!
Did you figure this out?
deanoE30M3
Which fuel pump did you go for Renault one?!
In all fairness the car has been stood for a few years, but do believe it’s got a key/ecu problem too.
Wouldn’t hurt changing the fuel pump to be on the safe side!
