Starting problems
Car  172
Right. I was driving along as per normal. 70mph on ring roads. Then all of a sudden cut out. No warning lights. Revs went straight to 0 and ignition lights came on. Ive got it recovered home. Ive checked all earths, connectors and sensors to make sure nothing is loose or damaged changed ht leads and spark plugs, sensor on gearbox, general examination of all wiring and fuses, airbox etc and all is fine...
It just keeps ticking over but just not firing up...
HELP!!
When it turns over does the engine sound "normal" eg. Has compression?
Not wanting to assume the worst but I'm thinking timing belt until you say it's got compression.
Unless there's something obvious wrong you're gonna firstly need to see what the ECU is seeing. If all there is fine then compression test it and hope for the best.
Mick
