rctempire
Any idea on how good this is?
http://www.steelseal.co.uk/
Basically her head is away and i told her this and the garage confirmed it. She needs to drive the car a short distance and she said someone recommened this.
I for one would never use any additive like this and didnt when my head went.
Anyone used it and how good is it?
Oh her car is a Renault Scenic 1.8l.
Im thinking ill just replace the head and gasket for her but she wants to try this before i do it.
I dont think its a good idea but its her car. Anyone think the same as me?
A great deal of valuable time and money can be spent on engine repair because of a cracked head or blown head gasket. Before you invest all that time and money disassembling an engine to repair a cracked head or gasket, try Steel Seal™, a patented chemical formulation that provides you with a convenient and affordable alternative to costly engine repair.
Steel Seal™ creates a permanent seal that will withstand high temperatures and high pressure. The product can be used in both petrol and diesel engines both steel and aluminium.
With adherence to the manufacturer’s directions and proper diagnosis, as a garage you will enjoy virtually effortless engine repair that will free you up to maximize the profits in your garage. As a member of the general public you could save £000's with the average head gasket repair costing in excess of £500!
What is Steel Seal™ made of?
Steel Seal™ is made of several chemicals that, when combined under the right circumstances, creates a permanent seal as strong as steel.
How does Steel Seal™ work?
Steel Seal™ is added to an antifreeze/water mixture and poured into the radiator of a cold engine. Once the engine is started and reaches operating temperature, Steel Seal™ is distributed through the engine. The product is drawn into the damaged area and seals the crack with a thermo-chemical bonding action process. Which is similar to that of an epoxy resin just in liquid form!
Will Steel Seal™ clog the engine’s cooling system?
Steel Seal™ is a clear formula that contains no fibrous materials or particles that could clog engine coolant passages. You can see that for yourself just look through the bottle.
Will antifreeze compromise the seal?
No, in fact, Steel Seal™ MUST be used with antifreeze.
How long will the seal last?
With Steel Seal™ the seal is permanent under normal operating conditions, but there is always the possibility of another leak in another part of the engine.
What will Steel Seal™ not fix?
Steel Seal™ will not seal leaks in hoses, seals, water pumps, or extremely large cracks in the head or block resulting in the vehicle not starting. If it does not run Steel Seal can not work as it relies on temperature.
What do I do if I have used an inferior product making similar claims?
The cooling system must be flushed thoroughly with water, NOT a flushing agent.
