Steering creaking!!
  Clio 172 FF
When i turn the car around on full lock it makes this awful creaking noise what could this be steering rack?
  Dodgy one
This is a 'feature' of the 1*2's iirc..
Someone confirm?
Correct, Shitty top mounts.
Its the top cap that does it, I took mine off and stuck some grease under it, It stopped for a few days and came back then went away Presumably because the rubber had softened up a bit
  Megane dci 130
As above. The repair on sports is to grind out the fouling area of the top struts. Renault dont recomend putting the expensive spacing washers on the sports for some reason.
