You can't adjust it on a mk2 by taking the wheel off. I had my alignment done which cured it. if you remove the wheel off the toothed bar of the rack has a pattern so you can only put the wheel on it a fixed position.
You can lift the steering column out of the rack at the t junction behind the bulk head and line it up correctly but its easier getting the steering laser tracked
