Register a free account today to become a member! Once signed in, you'll be able to participate on this site by adding your own topics and posts, as well as connect with other members through your own private inbox!
remove the top half of the steering wheel cowling, with a flat blade screwdriver press down GENTLY on the tab holding the stalk in place and simply pull it out.
I think it wires directly to the HU, so there should be the same number of wires at either end. Test for continuity and see if you can find a pair that dont match up, if you do there is your break otherwise it isn't your wiring.
