remove the top half of the steering wheel cowling, with a flat blade screwdriver press down GENTLY on the tab holding the stalk in place and simply pull it out.
I think it wires directly to the HU, so there should be the same number of wires at either end. Test for continuity and see if you can find a pair that dont match up, if you do there is your break otherwise it isn't your wiring.
