Sticky handbrake?
  Abarth 595
So here we go...the last time I posted in here it ended badly 🤦‍♂️
After a resonable drive, my offside rear wheel has a bit of a burning smell, as if the brake pads have been used a lot. Could this be a failure in the handbrake cable perhaps? The handbrake works fine but im guessing maybe its not releasing completely? Any simple fix to this I could try?
MRBILLYUK
  FF Jeden Osiem Dwa
Jack the back end up with the handbrake off . If you can't spin any of the back wheels freely you have a sticking caliper.
Also, if one of the wheels is hot after a good drive that's a good indication you have a sticking caliper.
  Abarth 595
So, I had a mechanic come and have a look today. He told me he gave it a good clean and changed the pads and he could tell it was sticking, but now claims to have fixed it. I questioned the bearing as per @Daniel comment and he said its fine - not sure if I believe him on this as there is a definite sound coming from the wheel still. What else would be a sign that the bearing is fucked?
Sheilas’ Wheels
  Whichever has fuel
Jack the rear end up and spin the wheel up. If it’s still sticking he hasn’t fixed it. If it’s grumbling the bearing is shagged.
also, hold the wheel at 3 and 9 o clock. Rock the wheel. Then do the same at 12 and 6 o clock.
if you’ve got any movement the bearing is buggered.
  Abarth 595
Nice one will give that a go now. He did tell me it was spinning freely and there was no movement, but i was in the office and cant see him from where i was so was just taking his word for it tbh.
  Abarth 595
Okay, I’ve just jacked up both back wheels and they both spin freely and there is no wobble. (It didn’t take me 3 days to do this - had to go buy a Jack). Anything else worth me checking before taking it back to a garage? Could it be the tyres making noise? It starts from about 40mph onwards. They looked fine but I guess it could be hard to tell.
