Stock head unit wiring questions
Car  Clio 182 FF Arctic B
Hi,
I have purchased a second hand 8" active sub woofer to increase the sound quality of my Clio.
This sub can accept high level inputs and this is what I intend to use. I do not want to replace the head unit as I like the steering wheel controls and I have my Spotify plugged in using the 6 CD changer port.
I have a few questions relating to this:
1) High level inputs require a speaker wire from what I can gather.. Will the speaker wire from the rear speakers stretch? or is it a case of hooking up additional speaker wire to the rear speaker wires?
2) Regarding the remote turn on lead.. is there a dedicated port on the stock head unit? I presume not.. in which case what is the best practice in this area?
Thanks for the help!
You will need to extend the speaker cabling.
If you want a proper remote turn on rather than ignition feed you can use the cd changer turn on.
