Stop and handbrake light flashing!
  Clio 182,Ducati 888!
The other day the 2 lights on the dash started lighting up,can anyone point me in the right direction,and if its a sensor going will it show up on a fault reader,cheers!.
  192'd BG 182 FF
I have this and yes it only comes up after a long left hand bend on my way to work, anything to worry about? Fluids are all checked and fine. Cheers!
  PB172,dci100,dci65
Just to be sure, let someone push your brake hard and look if it leaks somewhere under the car. Brafe fluid should not dissappear.
  172 cup
I have this problem too but doesnt seem to be brakedluid, i have just changed discs and pads and put new fluid in, any ideas??
  182cup & 172 racecar
Was it on before you did the work? If not, you may have disturbed the plug on the cap, or take the cap off, shake it about and retry.
