Register a free account today to become a member! Once signed in, you'll be able to participate on this site by adding your own topics and posts, as well as connect with other members through your own private inbox!
Hello Past couple of days my STOP and Handbrake light have been flickering but today it came on solid without no flicker. Does this mean something is loose or something more nasty is wrong?
which means your pads are low, DO NOT just top up the brake fluid, replace the pads
brake fluid doesn't get used up, consumed etc etc, there is always a set amount in the system, when the pads are low the pistons in the calipers hold a larger volume of fluid and therefore the resivoir level is lower = light flickers on dash
It is more likely to be the front pads which need changing, as they do more of the work and have a longer travel in the caliper when they wear, but it might be good to check all of them.
Mine did it, and changing the front pads made the fluid level return, thus no more warning lights.
