STOP and (!) warning light
Car  182FF with cup packs
Every so often, especially if I am on a bumpy road or going up hill, the STOP and (!) (brake wraning light) will flicker on and off.
I'm assuming that my discs or pads need changing, or is it an electrical fault.
Strangely, they sometimes come on when stationary, but tend to go off if I depress the clutch hard and the pedal hits the floor.
So time forr new brakes you reckon?
hmm, if the brake fluid is low, it must be spectacularly low as i put 1/2 a bottle in when it first started doing it (being thats what the manual said it was)
I'll check my pads out instead.
^^ur pads will be low and when u push the cylinder back that extra brake fluid u put in will want to come back oot!!!
