Strange Electrical Faults on Clio 182 (2005)
Car  Clio
Hi all,
First post on here and I'm hoping someone can help me out!
Car year and model: 2005 Clio 182
Got some weird electrical problems… I’m fairly sure these three all started going wrong at the same time as always use them all on nearly daily basis.
-Driver side electric window works with ignition switch in pos 1 and 2 and with engine on, but the one touch does not.
-Cigarette lighter socket works when ignition switch in pos 1, but not pos 2 or when engine running.
-Blower motor does not work at all. However, when testing the resistor pack, the motor does work with pins 1 and 5 connected when the ignition switch is in pos 1, but not in position 2 or with engine on. (I did actually replace the resistor pack in March due to the blower motor not working but symptoms were different)
-The clock and temperature is only illuminated when the lights are on. (I have an after market sony radio so not sure how this display is meant to work!)
-The passenger side electric window is not working at all. This one might be unrelated as I hardly ever use the passenger window?
If anyone could advise? I have tried to find info online but was unable to find any forum posts related to all the above issues going wrong at once!
Thanks a lot!
Sam
