strange engine whistle?
  172 ph1
right...since about 10 mile from home on sunday coming back from silverstone obviously totally warmed up etc the car started making a whistle type noise when accelerating hard! so first time since then ive just drove it earlier, warmed it up and gave it some beans same noise again then it didnt do it as loud again...cant really explain the noise any better than a whistle but i have noticed unless its just me the car seems to pull alot better in every gear??????? my brother explained it to sound either turbo'd or supercharged lol?
cheers
  106 Quicky
Your engine is about to blow up! Na just kidding could be the air intake pipe has a small hole in it making a whistling sound or could be a little blow in your exhaust causing it to whistle, but most likely to be your air intake pipe. If it feels better through the gears it could be sucking in more air which is making the engine run abit better like a k&n would do. Correct me if i'm wrong i'm just guessing here lol, good luck with find the problem though ;)
  172 ph1
had me going for about 2 seconds there ya b*****d haha....cheers for the input lads! just cant explain it dont think its coming from the cats tbh but ive got a funny feeling about them been broken anyway so maybe get a decat after the mot next month and see how that goes
  Renault Sport Clio 182
If you do that ^ you will still need to get a new manifold > Cat fitting kit from renault, as that seems to be the most common fault that causes the whistle
  RB 182
No. If its your exhaust you might be a little down on power / fuel consumtion may be slightly up, but i didnt really notice much difference after replacing the gasket.
