Mick, thanks again. To explain further a bit, I took a seemingly well running car into an exhaust fitter, that developed an immediately apparent fault whilst on their ramps. I will not mention their name until such a point I can establish more. If I cannot establish more then I will chalk it up to experience and move on.
Sorry, I don't get why the A/C is such an "issue" though as its just an ON/OFF switch
It's not really an issue, it just suggested to me that the car had been driven, when they swore blind it had not. When I asked who had turned the aircon off, they stated it had been done by the OBD reader.
Who carried out the timing belt work?
AP Developments. I have already spoken to Craig, the car was running really well since he change the belts and gave it full service and plugs, for the last 500 miles plus. I have only good things to say about his quality of work and professionalism.
- If the engines timing IS the problem then the question is what has gone wrong, why it went wrong and then, what it needs to rectify.
This is the crux of the matter. Whatever the fault is, it happened whilst in the care of the fitter. It is perfectly possible that a coil pack, or a ht lead, developed a fault the moment it was on the ramps. I am sure this happens all the time, and would be of course no fault of theirs. The fitter suggested that either the coil pack was going or that the timing was off. If the car has been running fine for 500 miles, is it possible for the timing to
become wrong suddenly? That is my concern. It may be a false concern, the car seems to run ok at various points in the rev range, with an intermittent hesitation.
I am planning to change the ht leads and coil pack initially with some investigation at a decent local garage, if that fixes it then great. If it does not then I will get the timing checked, Craig has of course offered to check this for me at no charge (he is confident that it is not/was not wrong, as it ran fine for 500 miles and he is confident in his work - and so am I) but it does take me a significant amount of time to reach Craig, so can a Renault dealer be trusted to check the timing?
