Register a free account today to become a member! Once signed in, you'll be able to participate on this site by adding your own topics and posts, as well as connect with other members through your own private inbox!
When I take the 182 into higher revs, you can smell it. When the windows are open, the smell is a lot stronger. It's comming from the engine. I'm sure I have an oil leak, so can it be the smell of oil? Can't describe the smell
i had a problem with mine, in that there was a leak from the head, and slowly dripped onto the exhaust manifold. As it got hot, it burnt itself off. Never smelled anything though, more visual?
Worth checking at the back of the engine and seeing if there is a leak there?
Apart from that, take the intake manifold off, and see what you can see?
