Stripping Out Interior
Car  Clio 182FF
Greets,
What can you remove to save weight? Considering gutting everything not needed that's just dead weight (i.e. rear seats). What else can you take out?
Also, any tips for getting the rear seats out and also if stripping anything will fail an MOT?
you can take out:
rear bench
boot carpet
parcel shelf
passenger rear door cards which include speakers i think
headliner
all three seatbelts
carpet around the rear struts
plastic mount parts that hold the parcel shelf up
cant really think of anything else
^ Edit: I'm too slow...
I never use the back for anything, don't have a spare anyway because its a 182. The only thing I can think of is rear seats, parcel shelf, rear door cars and speakers?
Taking the rear seats out, they're not connected to anything electrically are they? The car won't know they're gone etc?
Hmm will have to digg around a bit more. Have searched but sometimes there are too many results to even begin going through.
Putting some turini's one should shave a few more Kg's too.
yeah as far as i kwow the ph2 models - not sure on cups - have the tensioners in the rear belt set ups too. need the same resistors as you use in the fronts. 3.3 ohm resistors.
it will put on serv and seat belt lights on on the dash if resistors arent used.
Yeh, but the results are going to be negligible!
The only way you'll notice any difference with stripping, is if you do the whole nine yards and guy EVERYTHING out that doesnt make the car move!!
to be fair, if you put in the research, you'll find 99% of the information somewhere on here. i did a load for when i wanted to take my rear seats out and fit my buckets. and it worked a treat - as there was no precise guide. its just a case of piecing it together and using a bit of common sense.
Ok cool. I'll go back further and see what I can find. Though if I am going to have to start playing with resistors that sounds like a ball ache.
Cheers as always d00ds. :approve:
Il help you with resistors fella :)
Sorted danny (djroberts on here) out with his :)
Sweet mate, I'm going to fold the seats down and take the parcel shelf out to start with and see if it's much louder and how it feels with the space then if I'll give you a shout if I like it. :)
it aint really that much louder. it is - but not really noticeably. and ive got a stealth on mine too.
With my rear seats out, there's a lot more road noise from the back, obvious really. Its not unbearable, but you do hear things you couldnt before, like the rear brakes!
Really? Mine's really echoey and I can hear everything I run over and when it rains I can hear when my wheels run through puddles lol.
dunno then i might be going deaf!
mine really doesnt seem anywhere as bad as i expected it to be.
mines quite loud tbh but i love it :)
to sort the front pretensioners take the buckle mechanism off the seat along with the pretensioner then cable tie it under ur bucket then get an old seat belt buckle plug it in then job done :)
Matty
