Strut Bolt spacing of a 172 front hub
Gaz_
Car  Extreme mode
What is it? Dont want no guessing, so only those in the know!!! Cheers
Cheers, this site is mint, but f**k me there is some conflicting info!!!
Thread the other day said 58.......
52mm and 58mm are only used on non sport hubs afaik
all the 172 hubs ive had (ph1 and ph2) have been 54mm
182 Cup/Trophy are 60mm IIRC
Well I'm running 54mm coilovers on hubs I removed from 172 Ph1, lol
Got spares that have been machined down for my car also, one from a Cup and one from a 172 FF....both 54mm too
see, ffs!!!!
I know cup-packed are 60mm for sure, just cant remember 172 ones. Might be a purchase in the pipeline but i need to know 100%
LOL, I really cant be arsed going getting the hubs and a set of verniers to get pics.
I will just remain confident that what hubs ive personally had and used from 172s have been what ive said above, and let you believe what info you want lol!
lol! I think its 54mm too.....
Got some H&R's in the shed, so i'll measure them when i get home. Fooking CS!
Lol^
Just nipped out and got some pics...
172 Ph1, removed from X Reg/2000 model...
172 Ph2 FF, removed from 52 Plate model...
Could only find a WHSmith shatterproof ruler, lol.
AFAIK the only model that is different on the 1*2s is the trophy, as well as possibly some variation of the 182, which are 60mm...but considering the thread was 172s, there you go :)
There you go then....the answer is unknown!
Out of the 7 hubs Ive got (with two on the car) they are all 54mm, so who knows!
M14 bolt is sport models yeah.
M12 bolt hole was all non sport (1.2/1.4/1.5/1.6), which is the same bolt size as a Mk1 Valver/Williams.
AFAIK from reading, and from dialogys/tech notes, all non-sports were either 52mm or 58mm........but oddly the Mk1 Valver/Williams were the same hub (use same caliper/disk/bearing) with 54mm spacing, not 52mm or 58mm.
I'd like to see photos with these claims of 58mm tbh. Mine are 54mm, from a 172 Cup; the same as ALL 172's.
Edit. It's actually wound me up reading this thread :banghead:
Tis indeed 54, checked before. How can some be 58mm....................... goons ;)
proof of your 58mm bolts then..........?
