Clio 182
Ok so heres the background :
For several months the front left brake has been noticeably hotter than the drivers side [to the point where the alloy can't be touched] - upon closer inspection the pads had been EVENLY worn to the limit.
Because of this , i have replaced both the disc and pads and lubricated everything.
However following all this the front left is still ridiculously hot [ majority of heat is from caliper itself]
I am under the impression that if the piston is seizing/sticking then the pads would be unevenly worn [correct me if wrong]
The car brakes straight and braking performance is fine.
Any ideas as to what may be causing the problem ?
Thanks in advance.
Thanks in advance.
