Stupidly Hot front left brake
Car  Clio 182
Ok so heres the background :
For several months the front left brake has been noticeably hotter than the drivers side [to the point where the alloy can't be touched] - upon closer inspection the pads had been EVENLY worn to the limit.
Because of this , i have replaced both the disc and pads and lubricated everything.
However following all this the front left is still ridiculously hot [ majority of heat is from caliper itself]
I am under the impression that if the piston is seizing/sticking then the pads would be unevenly worn [correct me if wrong]
The car brakes straight and braking performance is fine.
Any ideas as to what may be causing the problem ?
Thanks in advance.
Thanks , I thought it might be the caliper but i was told it would show signs of uneven wear .. my next step is to replace the caliper i just wanted some other opinions before shelling out for more parts :)
