Stupidly squeaky brakes :(
Car  Megane R26
Well Monday just gone, had a brake upgrade done. Brembo HC's, Mintex fast road pads, braided lines and Dot5 fluid. Now car was Ok first day, but now it sounds like a Bus. No lie. Get the most amazing squeek ever. What can I do. I know performance pads can make more of a noise but this is bluddy stupid. Worth using cooper slip on the back of the pads. Help. I don't want to sound like a Bus anymore! :(
TADTS [They all do that sir!]
I had the same setup on my VX and they squeaked all the time, you normally get squealing brakes with high performance aftermarket brake setups.
I fitted grooved and drilled disks after which eliminates the squealing but I prefered the solid disks.
Get used to it!
PS.... Did you apply loads of copperslip to the rear of the brake surface? if you didnt - this is normally the reason of squealing [you can buy anti squeal pads to apply to the rear of the pads too ;)]
Ahh I see, this is just more than a sqeek!
I got some anti squeal pads by the look of it with the rear pads I didn't use. Wortyh fitting these then. Also what do you mean by the rear of the brake surface? Cheers
MrStabby said:
Cool, will be doing this sunday! You reckon the pads or copper slip will be better?
Both!
The actual brake surfaces will probably still squeal though [disk onto pad surface].
